Finding the Time code on QT Proxies
Dexter Gregoire
Vancouver, Canada
I have RED ONE locked to SD744t, press the record button on the recorder first then the camera. When I bring the QT proxies into FCP the time code is the time that the footage was recorded. Where is the time code? What setting am I doing wrong? OR does QT proxies not display time code on build 16.
Timecode and FCP
Timecode and FCP
I have RED ONE locked to SD744t, press the record button on the recorder first then the camera. When I bring the QT proxies into FCP the time code is the time that the footage was recorded. Where is the time code? What setting am I doing wrong? Or does QT proxies not display time code on build 16.
What do you mean by "time code" in this example? Build 16 is working as expected.
In FCP the audio file is off by alot. During record everything was in sync. I read the Sound Devices manual and found out that maybe 48Khz is not the choice I should be choosing. Instead 48.048K or 48.048kf. Do you know which one I should be using? I'll try running more tests before calling Sound Devices support.
