When I go to the SYSTEM menu, select MONITOR, then PREVIEW and set this to Menu(DVI) I get the full camera operation menu's through the HDMI port. This is really great. Problem is from what I have been able to understand from the manual and tests I loose use of both of my HD-SDI output's and the 720p output when in this setting.
Having the full camera operation menu's through the HDMI is something I would really like but I need the use of the HD-SDI signal out as well at the same time. Is there any current way to do this or is there the possibility for this to be an option for both to work in future builds? I am currently on build 15 so maybe this is already a feature in build 16 or maybe there is some way that I have not found to do it with build 15?
Any advice or information on this from redusers or the red team would be very helpful.
Daren
Daren
