- Thread starter
- #101
Jannard
Red Leader
- Dec 28, 2006
Jim, can we who use the Arri 15mm Studio spacing setup expect accessories from RED that match that spacing and setup?
Rion
Yes.
Jim
Rion
That's right. I prefer having the modules be Scarlet size than Epic because it would be more compact and lighter.
Then nothing would fit inside the modules...
Jim
Because they're both being classified as DSMC units. To me comparing the 5D/7D to RED's stuff is like comparing a Bicycle to a Motorcycle. They both have two wheels, but their two different things.
So if the modules have epic size, why is there the epic adaptor behind the epic brain?
Just curious!![]()
Jim, is the large render of the camera from 2 different angles a SCARLET or EPIC? I notice that multiple people have asked the same question. Also, is the lens a mini series or pro prime and what will the 2/3" Scarlet kit include? (Im assuming EVF or LCD, Handle, and some sort of I/O audio module)
Thanks for all that your doing with this company and keep up the good work!
Jon
Perhaps you can have a 1:1 on the LCD for focusing, while the EVF gives you everything? That would be useful!
Well in truth that could be in deed the Scarlet and not the Epic Brain, but thing is that the Adapter Module seems back words any ways were it should be front small to fit the Scarlet and back Large to fit the larger size of the Module and not as it is pictured in the recent posted picture, but it does says Epic Adapter and not Scarlet Adapter, so here it looks as the Modules were smaller then the Epic Brain, and there for the Epic needs an Adapter to the Modules, so much ???
Then again, why speculate so much about something we know so little![]()
Just curious!![]()
Rough idea of modules...
Since it's RED, I'm thinking maybe there are slightly different sizes of EPIC's. If it was Canon, they would make it a few mm's off so you would have to give them more money for an adaptor. :smilielol5:
