Sam Roberts
Sorry, Sam -- I erased your message when I typed my answer, by hitting Edit instead of Quote, an option that Moderators have. The two buttons are right next to each other. David Mullen, ASC. The post below is by me, not Sam. His question was why does a smaller sensor produce more depth of field.
Sensor or film size affects field of view and degree of magnification (which affect the circle of confusion figure used), and field of view affects focal length choices.
You go to a sensor that is half the size and you have to use a lens that is half the focal length to get the matching field of view, and while a focal length that is half the size would show a four-stop increase in depth of field according to charts (at the same f-stop and distance focused), the fact that the smaller image has to be doubled in viewing size to match the image from the larger sensor means that the circle of confusion figure you chose is cut in half, made twice as critical, so a four-stop difference becomes a two-stop difference.
The 35mm frame is 2.5X larger than a 2/3" sensor, so the effective difference in depth of field is 2.5 stops, i.e. once you match field of view by using a focal length that is 2.5X shorter on a 2/3" camera, and you use the same f-stop at the same distance to subject, you have gained 2.5 stops more depth of field, as if you were shooting in 35mm but had stopped down the lens by 2.5 stops.
