RCX PRO Build 11 Beta and Epic/ Scarlet Camera build 3.0 (release)
* EVF black level raised in some casesGREAT!
This operational note has not changed for many builds. Alas, I think this means your EVF will still be milky. Am I mistaken?
I'm totally with you on this Mark. The EVF could be sooooo good with this simple firmware fix.
Same problem here ROb with 10.5.8.
Process: REDCINE-X PRO [337]
Path: /Applications/REDCINE-X PRO.app/Contents/MacOS/REDCINE-X PRO
Identifier: com.red.RedCineX
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [65]
Interval Since Last Report: 613175 sec
Crashes Since Last Report: 103
Per-App Interval Since Last Report: 0 sec
Per-App Crashes Since Last Report: 4
Date/Time: 2012-03-06 09:51:11.570 +0100
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: D4835A2D-AB9D-4F5B-8BC1-66C032F2417D
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Symbol not found: __ZNKSt13bad_exception4whatEv
Referenced from: /Applications/REDCINE-X PRO.app/Contents/MacOS/REDCINE-X PRO
Expected in: /usr/lib/libstdc++.6.dylib
Best regards
Robert M.Berger NSC
Epic-X 00274 "ED" and R1 1265 MX SSD
I made a tiff snapshot with unsharp mask on and it seems there was no sharpening done to the tiff. Windows 7 64 bit.
Hi,
Is there audio enabled during playback.....
thanks
Harcharan
Looks good on previous footage.
Might we know what has changed in basic technical terms on the new V3 release ?
Jarred, love ya work... really do... but!
* EVF not supported in playback... NO, NO, NOOOOOOOO!!!!! I live in my EVF... Will this come back very soon mate. I'd hate to have to swap cables every time I want to playback a shot... I cannot upgrade until this is working again.
All the other stuff sounds great!!! Better than great!... But please get PLAYBACK going again in the EVF... Pleeeeease. :)
Mark; I updated to v3 and I can still playback through my Bomb EVF. Still milky blacks though. Possibly slightly better?? I dunno...might be my imagination or wishful thinking. +1 on the milkiness. If they fix that the Bomb EVF would really be the bomb.
I love that that the post fx such as Alchemy, Saturation, Unsharp Mask, and Film Look are able to playback real time with a change of the cpu usage in the preferences tab!! Great update!! Always disliked the previos builds slow load for these.
:cheers2::cheers2::cheers2::cheers2::cheers2:
When I open RedCine X Pro I get the message Red Rocket #0 driver or firmware is out of date. this version requires driver 1.4.19.0 and firmware 1.1.16.5 The last time I upgraded the firmware on the red rocket it killed the thing and I had to go 6 months with no rocket card because I couldn't get it back to the USA for replacement. Is upgrading red rocket now safe?
WOW...This is simply amazing..!
TY RED..!
Congrats Red Team, can someone send the SDK tied up to a roadrunner to BlackMagic HQs?
You have to go to full rez and then apply it. Otherwise you will be looking at it in lower resolution and therefore be to gentle.
Try to crank it up the amount to 200 and you should se it clearly. Warning this looks horrifying in 1/2 res. Then change the values to something that fits youre taste.
Me personally love the unsharpen since I think all cameras have to make up for the lowpassfilter in some degree. Just be sure to look in full res when dialing in sharpness.
Best luck
Joel Arvidsson
Subtle changes to skintones and overall? ... NOOOOOOOOO! This has to be the most radical subtleness ive seen in a loooooong time. Skin has microtonality / microcontrast now like never before.
Working with an eye towards print most of the time, the sharpening so much dreaded on here is soooo welcome inside RCX.
Best luck
Joel Arvidsson
I actually can see the sharpening just fine inside RCX-Pro even at lower resolutions. The problem is when I output a TIFF snapshot there is no sharpening applied to the outputted TIFF file :)
On a positive note RC3/RG3 definitely lives up to the hype! I love the results I'm getting. I'm also really happy to see that my video card (GTX 580) is now supported! With the previous release I was stuck using my laptop because of video card compatibility issues with my workstation. About to update my Scarlet now and my OLPF port bushing just arrived :)
The changes in RC3 are anywhere between subtle and spectacular, depending where you look. Check out a few examples I've uploaded with roll-overs for comparison.
