- Admin
- #1
- Dec 27, 2006
As mentioned. I think you guys are on to a pretty sweet thing here...
This will probably sound dumb, but when I'm looking at a Magic Motion shot what details should I be noticing? Maybe it's because I don't have a basis for comparison right in front of me, but I am having a hard time noticing its distinguishing characteristics.
The motion does indeed appear very pleasant. Have you tried to test a moving semitransparent object? The point is, if you see somewhat through a moving object, is there any side effect in the background that should remain stationary?
Great question... as compared to "normal" motion, there is more "reference" sharpness (or temporal resolution). This is +3 which is the most "normal". At +6 you get much more of the temporal resolution and sharpness of the moving object.
If you can't tell a difference (trust me that you can in a direct comparison) you get 3 stops more DR. That is a good thing.
Jim
So when you say +3 and +6 do those numbers correspond to added stops of dynamic range or is there a magic motion setting that is independent of the increased DR in HDRx™? Sorry if this stuff has already been covered.
The more I look at that clip, the more I can't put my finger on "it". The motion is very hard to describe in comparison to what you'd expect.
The amount of added dynamic range (and "Magic Motion") is numbered by stops... +3, +4, +5 & +6.
You select. The higher the number, the sharper the "other" stream is...
I am set on +3. But I can see times when I would select higher.
Jim
Jim, could you perhaps shoot a scene like the one you've just posted, but with two Epics side-by-side? Set one for HDRx™ and MagicMotion and have the other shoot normally. Edit the footage as such that the clips appear side by side, time synced. This way we can compare the two types of motion, in real-time, side-by-side.
Since we can't quite do that ourselves, would you mind throwing something together?W3e can do better than that. If you drop the "x" frame stream... you have normal motion.
Jim
