- Thread starter
- Banned
- #101
Conrad Hunziker
Banned
- Mar 9, 2008
- Los Angeles, CA
- www.r3ddata.com
When it works, it seems to knock it out fantastic, but I've started to occasionally get straight errors in the logs. I always get Copy OK, but then:
"Source verify after copy Error!" and "Destination verify Error!"
So I delete the folder and run it again. This time I get straight down the line:
"Source verify after copy Error!" and "Destination verify OK"
The source verify after copy error means the source did not read the same data twice the same way. Something in the file changed so it wasnt the same checksum.
The destination verify error means the destination checksum didnt match the source checksum.
Its up to you if you want to ignore them, but please make sure you are visually verifying the footage.
Really, it sounds like either your system is dieing, or there is some other process interrupting the copy. Or I suppose it could be a bad stick of RAM, since 6.1 is more RAM dependent.
But I would advise moving off this equipment until you get it all sorted.
BTW - 6.0 and 6.1, the new copy process, is pretty well tested. I use the code on all the red shoots, and theres a select bunch of beta and heavy-use testers, in addition to all those who have upgraded since NAB. None have reported this issue.
