Switching lenses with camera on?
Lars Wikstrom
Hey, still getting use to my first Red camera. Normally my DSLR's I would power down and switch lenses since it only takes a few seconds to power them up. But the Komodo takes some time to boot up so I thought I would check first if it is OK? Thanks.
It's totally acceptable to swap lenses with the camera running. In fact, the quicker the better or you'll have a very upset AD breathing down your neck! :lol:
Good to know, thank you. Wasn't sure if it would harm the sensor or not.
No problem! Just be careful as you're swapping and don't let anything but the lens in there! But that applies to any camera.
No problem, this is standard on cinema cameras, there's no point it off.
I assume that there is no risk of getting dust on the sensor?
Why would the risk be more or less based on if the camera is on or not? Look at pro photographers who swap lenses all the time, fast and pretty roughly when hunting those perfect moments.
Problems with sensors rarely come from dust and physical stuff but most often from bad electronics, dead pixels and other stuff internally. I've rarely seen a sensor break down by anything else than bad manufacturing.
Because when the camera(sensor) is on, there is basically a static charge across the sensor and particles, dust, etc. are attracted to it and land on the OLPF. It may have been the original C500 or PL mount C300 that had a button that basically shut down the sensor so you could change lenses without shutting the entire camera down.
And I would never take operating technique from a still photog and carry it over to motion. I’ve spent my entire career shooting next to still photogs in the sports world. Half of their time spent in post is cloning out spots of dirt from their filthy lenses and sensors. One of my friends(still photog) was giving me crap one day telling me I had the cleanest lens he had ever seen. Which isn’t really a major accomplishment when compared to how they treat their lenses.
Good points there, Christopher. It's also worth pointing out that some cameras have an anti-dust feature.
Yep. Most modern “DSLR’s” from roughly the last decade have this type of feature and it’s usually automatic on either power-up or down (or both) and can usually also be activated manually. I know on my Canon’s I can actually hear it shaking the sensor. It sounds like a couple of faint squeaks.
Fair points, but I've rarely seen problems during shoots. Lenses are switched all the time on productions without turning the camera off and it's never a problem in post, at least on the ones I've been involved with.
I am not so sure I would have confidence in hot-swapping smart lenses with a self-owned camera. Professional level cameras and lens systems may have protections built in. They may also be more likely to be rentals so you don't have to be the mother to worry.
For the self-owner, the idea of something going wrong with one of those pins on a consumer-level autofocus lens into a non-OEM mount with power going through everything would make me a little anxious.
Think more haste less speed. We have all read and heard those horror stories about pins being mashed out of lens mounts. It is not like you might be carting two of three stills-camera bodies around to a job.
I never shut down my camera to swap lenses. I've been running RED since 2009. No problems yet!
It’s also impractical. DSLRs start and shut down in an instant, while Red cameras take time, so no team would have the patience of waiting for every change of lens that happens during a shoot.
The main thing is, as always, that you should always have a cleaning kit with you when shooting. If there’s any dust particles and stuff getting on the OLPF, just blow or wipe it off.
