Häakon
Pinned the topic for new users to read. Very nice collection of FAQs and information.
so, what exactly do these lenses mean?
6.5mm T1.9
8.0mm T1.5
16mm T1.5
25mm T1.8
50mm T2.9
75mm T4
ok. Here goes - an embarassing question;
WIll te REd Scarlet 3k files work on a 2008 macbook 2.0 ? Can it handle the red code ?
And if my mother and pet monkey wanna use it and myself... do these files work with IMOVIES or FINAL CUT - and if possible could someone tell the bare minimum you require to work with the Scarlets files... ?
Will there be a highspeed usb port on it ?
Thank you, tak
Also where will the Scarlet be available to buy In Tokyo ? (When released)
Sorry for my very basic questions...
I have a macbook 2.0, Imovies and only a high speed usb port !
What would get me started ? I would like to think this camera is compatible with this equipment and something exciting about that if it happened.
So yes, you could use it to edit with, however with really small proxies, or really compress down the files to edit with.
Actually editing REDCODE RAW files isn't too bad on a laptop using Adobe Premiere. You just drag n' drop the R3D files right on to the timeline and choose resolutions from full to 1/16 on the fly. No rendering times whatsoever. You can edit smooth footage at 1/4 or 1/8 and then switch to full rez with a click of the mouse to check focus. You also have access to the RAW controls from within Premiere. I think all editing programs will have to head this way eventually.
The 6.5mm is the wide lens, 75mm being the long one.. Compared to S35 format, these lenses would produce roughly the same FOV on the 2/3" format as a lens twice their focal length used on S35.
