Guilherme Belchior Afonso
- Feb 4, 2013
- Lisbon, Portugal
- vimeo.com
Hello everyone,
I recently upgraded my Scarlet to the Dragon sensor and I´ve made some tests with the STH OLPF and the LLO OLPF and I´m not that impressed. The colours look good and the extra fps are very welcome. But the noise doesn´t look that good. I have already read about issues with noise in other threads but I´m still not clear about what is causing it. I´m getting a lot of color noise in the dark areas. The LLO OLPF is a bit better but still...
I use 1.8 redmags and I know that the minimags are faster, but can I get less compression redcode levels with them in Scarlet D?
Looks like the Redcode options in Scarlet D are very high for the sensor to have a clean image.
I have some contax Zeiss lenses and when shooting at 6K 12 fps they look less sharp than they did at 5K in the MX. Is there any limitation with these lenses at this resolution?
I use the leitax adapter for the lenses with Canon mount, do you guys recommend any other adapter? Or should I change my lenses set?
I made the update just to keep it up with RED´s technology and I don´t regret but I feel like it was to much money for the upgrades and I guess that only in the Epic D with lesser redcode compression the changes are truly noticeable from the MX.
Anyone have some advices?
