Andrew Allsbury
Thanks Matt! Great feature!
Just blackshaded in 11 mins, which is fully half of what it used to take, cha-ching!
There are two 'layers' to what you're seeing on the monitor; the image you're capturing/previewing and then the user interface. This update allows you flip both layers vertically, and the UI interface can also be flipped horizontally (aka. mirrored). What cannot be done yet is to horizontally flip/mirror the image being captured/previewed. The description is correct but not as detailed as this. Hope that makes sense.
""This is useful for more unusual mounting positions of the touch screens,"
Permanent will store the imported map as your default user cal map (and will re-program the map on camera .. which will take ~10 min)
Temporary will allow you to use the imported map as long as the camera is powered up, assuming you don't re-black shade or reset to the factory or currently stored user map. However if you power cycle, the camera will revert to the map stored in it's internal memory. This operation takes only about 15 seconds. This mode is intended as a time saver in case you have some maps stored off camera and need to shuffle through them quickly.
here is the special build for cameras without a touch LCD
http://red.cachefly.net/epic/betatest/DSMC_Resources_v4.0.zip
So I've come across something weird. I am no longer able to use the display tools. If I select edge, video, or exposure settings ( I think these are what is available there I'm not in front of the camera) but basically the tools to allow focus peaking no longer do anything. i can click on them and nothing happen. View RAW still works, so does magnify, but otherwise they do nothing. I also noticed that if I try to change the red gamma or red color, I can change it, but nothing visually happens on the screen. Yes I have checked to make sure I am not viewing RAW. Can anyone else verify this with this build. I have rebooted several times and same results.
Just reaching out to see if this is a common phenomena with the new build. I'm getting this intermittently when changing resolution or switching to 1:1. The monitor fades and dies out over a few seconds, everything goes, the UI as well as preview image. It recovers and normal operation can continue thankfully, but for a moment it looks like the cam has lost all power.
I'm running on Scarlet.
Frame averaging is excellent - I've done this in post quite a bit using either 2 or 4 frame oversampling, great to have in camera... BUT
Wouldn't it be cool to utilise the motion-conjoined HDRx style capture to keep regular motion blur?
ie. at 4x intended frame rate capture two 90deg. frames sequentially, dump two, and capture the next two. Of course I can do this in post with 360 shutter and high fps, but it takes a bit of post work to implement. Would love it in camera too
Love these big updates![]()
