Warren Eagles
Active member
- Dec 22, 2010
- Brisbane Australia
- www.warreneagles.com.au
…under most circumstances, LUTs are used in a DI style pipeline - in other words, they are put at the output of the base grade, not before. Putting them before defeats the entire purpose of recording in a log format in the first place.
Are you coming at this from a Resolve point of view or a Baselight point of view?But under most circumstances, LUTs are used in a DI style pipeline - in other words, they are put at the output of the base grade, not before. Putting them before defeats the entire purpose of recording in a log format in the first place.
I know with Baselight, what we generally did was load in the source files, select the appropriate Truelight LUT for whatever color space we need, add a base correction layer, then do the final color-correction on an additional layer(s). Are you advocating using a LUT as a layer or node prior to all color correction, or as an overall preliminary set-up?
I think I see both your point and Warren's point. The question is whether you could engage all the parameters in a correction to precisely emulate a 3D LUT, and to me, it'd be difficult to get there 100%, so I agree with your general statement. But a simple LOG -> LIN LUT would get more than half the way there, just in terms of giving you more range and not having to slam the corrections (or build multiple nodes) to get an acceptable picture. In Warren's case, if he was only delivering Rec709 material, his method would work, but to me it wouldn't be ideal.
Heh... after watching the Resolve tutorials... I now read Warren's posts with an Aussie accent.
Hey Warren, I loved the Resolve course, fantastic stuff!
You sometimes refer to Center-Click, which I haven't figured out how to do. I keep my mouse set to just left/right click and can't figure out what you are doing to Center Click.
Silly problem to have but there I am.
Actually, while Warren has lived in Australia for +10 years he is from the UK, and most Aussies I know would say he has a London accent.
Either way the more guys and gals who offer their advice on grading, and using Resolve the better.
Peter
You really need a three button mouse to run Resolve effectively if you're running it on a Mac.
So no command-key combination to simulate a center click? Either have it or you don't?
I would have thought center click would just be a shortcut for something else, like option-click, command-nose-on-tab-key etc.
I'm just looking to apply the tips from Warren's FXPHD course.
