REDgamma3 LUT for Resolve
If you want to make LUTs to match different cameras, or similar, you can do that with the Light Illusion MatchLigth IMS program.
http://www.lightillusion.com/matchlight.html
This is already being used by a number of clients for exactly this capability.
The two images/sequences do need to be very 'similar' but with some user alignment of the two images/sequences the results are very good.
One well known operation (that can't be named) uses this to match cameras to within very tight levels.
Steve
$900?, no thanks anyway, like Björn said, I can cook luts rigth away too, just post the r3d charts.
One idea to stop this dumb Alexa vs epic talk. If somebody could shot a good chart with 16 steps of grayscale and all a (do no know the right word) a " stepped rainbow with an alexa and an epic in a somewhat lab like environment then it would be a no brainer to make a REDlogFilm2AlexaClog lut or even red could do this and next to redlogfilm add...... GermanLog as an option.
All the debate that alexa has more stops and better skintones is as I see it very much so that people do not really know what to do with the raw files, so they tweak it export Redgamma3 and then push it some more... and boom the face colors goes bad in the video color space. REDLogFilm is not far from alexa log but getting it dead on would put an end to the discussion I think.
Yes please
You'll find that a lot harder than you think... Charts do not contain enough data for accurate LUT generation.
MatchLight uses all the pixels within a sequence of images to generate very accurate LUTs.
Steve
Hi Nick,
Sorry for my dumb question but;
What is the difference ;
a-Selecting RedGamma3 in Resolve RAW
b-Applying your RedGamma3 as LUT in node section?
thank your for advance
//ergin
You will be grading in "video". The highlights will be compressed by the REDgamma3 curve, and it may be hard to expand the highlight detail. It is also easy to accidentally make your highest highlights grey instead of white.
You will be grading in log as is traditionally done with scanned film. The REDgamma3 highlight compression is applied after your grade.
But until you start making grading adjustments the result is the same (other than the black level adjustment as described in my ReadMe file).
Do not apply my LUT before your grading adjustments in the pipeline, or you end up grading in "video" again. Adjustments after the LUT should only be for specific trims which work better in "video".
BTW - The Resolve LUTs folder isn't located in the user "~/Library" folder, its in the "/Library" folder which isn't hidden (YET!)
Steve
Steve, I respect you, and your company, but I have to disagree a little. A smooth gradient grayscale image, (and something else that I wont mention here for obvious reasons) contain all the data you need. But you have your secrets, I have mine, lets just keep it that way.
Edit: And, I am sorry about the price criticism, I think, is fair really, considering the fact, that is a software that generates the LUT, but, isn't just for me, and that is probably because I know how to make them. (the hard way).
So can someone explain to me the purpose of these LUT's. I'm confused because you can essentially change it in the raw propertied back to redgamma...
Four posts above.
You [should] be grading in log as is traditionally done with scanned film. The REDgamma3 highlight compression [should be] applied after your grade.
Long story short, by starting from a RG3/709 base, you'd be needlessly crushing/clipping your footage by grading from a video starting point instead of using the most image information/detail that is in the log image (in our case, REDlogFilm). Don't get me wrong, the info is still all there in RG3 (it's raw), it's just harder to get at and may react to adjustments unnaturally...
