Danilo Del Tufo
- Feb 22, 2010
- QUARTO, (Naples)
- www.linkedin.com
Hello there, I’m pretty confused between REDCODE COMPRESSION and TYPICAL MAX RECORDING TIME USING RED MINI-MAG 120GB. For example I’ve read that at 3:1 maximum available REDCODE for 4.5K (4608 × 2160) at 24 fps means also that I could have a 3:1 compression also with a 120GB Mini Mag or Do I need a much bigger Mini Mag to have minor compression? Assuming that USING RED MINI-MAG 120GB at 4.5K (4608 × 2160) and 24 fps at 11:1 REDCODE compression we’ll have 52 minutes of footage, Can I select a compression 3:1 instead of 11:1? In this case do I need a more expensive card like 512 Mini Mag or 1TB? Thanks
