- Admin
- #1
- Dec 27, 2006
RCX PRO 16 and RED Rocket 1.4.28 have been posted live.
RCX: https://www.red.com/downloads/4fad7fd417ef027cd8000eb1
RR: https://www.red.com/downloads/4f56854d6261f95a57000669
Cachefly links are here:
RR:
http://red.cachefly.net/rocket/RED_Rocket_Installer_v1.4.28.zip
RCX:
Mac Installer Package:
http://red.cachefly.net/redcinex/appcast/mac/REDCINE-X_PRO_Build_16.pkg
Windows Installers:
http://red.cachefly.net/redcinex/appcast/win/REDCINE-X_Pro_Build_16_32-bit.msi
http://red.cachefly.net/redcinex/appcast/win/REDCINE-X_Pro_Build_16_64-bit.msi
CHANGES to REDCINE-X PRO SINCE BUILD 16 BETA
CHANGES to RED ROCKET installer SINCE LAST RELEASE:
RR:
RCX:
Windows Installers:
- Added: Epic Monochrome support. (software decode only)
- Added: Ability to disable Rocket warning dialog on startup.
- Added: Additional camera user metadata.
- Added: BWF exports can now include external audio.
- Added: Audio tab track selection is now remembered when changing clips.
- Added: JPEG Stills exports on Windows.
- Added: Ability to export Color compatible XML’s.
- Added: DRX support with RED Rocket.
- Fixed: Issue with knob sensitivity on Tangent Element with Sharpness, Denoise, and Detail controls
- Fixed: Issue that caused popping the video player out to a second monitor to fail in some circumstances.
- Fixed: Some metadata was not being displayed on exports with metadata burn-in enabled.
- Fixed: Fixed gaps and overlaps that occurred on the scrub bar on Windows.
- Fixed: Issue where the video position sometimes jumps a number of frames into a clip when setting an in point.
- Fixed: Issue where the cursor sometimes jumped to the end of the text field when editing metadata.
- Fixed: Player now returns to original clip when play is clicked after loading an image from the frame store.
- Fixed: Issue with log file generation for first ever runs of RCX.
- Fixed: Import of FCPXML (Final Cut Pro X) on multi-framerate timelines.
- Fixed: Export of timelines as compound clips in FCPXML project files.
- Fixed: Issue with QuickTime audio encoding when no setup has been performed.
- Fixed: Some keyboard shortcuts didn’t work on Windows when the video player is placed on a second monitor.
- Fixed: Crash could occur when clearing finished export jobs while an export was running.
- RED Rocket™ now supports DRX (with updated software)
