- Banned
- #21
CVB
Banned
Sleep is over rated anyhow. We're working hard to get several products out the door but luckily the software and hardware overlaps so we can leverage the design of one product and roll it into the design of another. We'll be posting info and new proto pics of the remotes in a few weeks.I sure hope Curt and the gang at View Factor can deliver their remote FIZ pieces soon. The combination of quality, price and integration into the RedOne architecture is very attractive.
No sleep for you Von Badinski :matrix:
Yup, the design has changed... price is still the same (or less).http://viewfactor.net/forum/index.php?topic=14.msg53#msg53
There is some info about Curt's wireless follow focus on the VFS forum. I'm sure the design has changed from the renders shown, but the price probably hasn't. $750 or less for the Standard Impero.
Prepare to be fathomed.A growing number of AC's are moving to working with remote focus for all applications. However the need for such a system to be super reliable, accurate and fast is critical with a 35mm front end. It is unfathomable to me that a remote system that can approach the performance of a standard follow focus could cost less.
So does red's...Also understand that each time a lens is changed, the remote system needs to be recalibrated for that lens. The high end systems (Preston, C-motion) will automatically do that with a high degree of repeatability, allowing one to reuse marks from previous times that the lens was marked out.
Our remote is completely digital all the way from the 14bit resolution (.04 degrees) on the control knob to the zigbee transceiver that digitally encodes all the data before transmission... so basically no erratic behavior. You can run as many units as you like right next to each other and have no interference problems. A super-low cost wired version of the remote will also be available.Having suffered through 3 early models of remote lens control before buying a Preston 10 years ago, I can tell you that it's a white-knuckle affair, having to deal with erratic remote systems for both operator and assistant. Buzzing shots is not sexy or an arguable "choice", they are just plain out of focus and the enhanced resolution of RED will only amplify this.
