RED V-RAPTOR Firmware 1.5.2
Vedran Strelar
Active member
https://www.red.com/download/v-raptor-firmware
SIGNIFICANT CHANGES SINCE RAPTOR 1.4.4
  • Added support for RED RF TO PL ADAPTER W/ ELECTRONIC ND
  • Added RED Connect License support
  • Added ability to edit FPS, Shutter, and Format lists.
  • Added upcoming clip filename to SDI HANC while in preview
  • Added Format Dimensions status
  • Added RF Iris Compensation
  • Added ND control to assignable buttons list
  • Added ND Increments to Lens & Histogram Page
  • Added DSMC3 RED TOUCH 7.0" FW 5.4.1
  • Added RED Pro CFexpress 1TB support
  • Added Angelbird AV PRO CFexpress 1TB MK2 support
  • Added RED PRO 1TB support
  • Added OWC 1.3TB support
  • Added Prograde 1.3TB support
  • Added firmware update prompt and automatic restart
  • Added firmware update over USB Type-C
  • Fixed proxy timecode offset under certain formats
  • Fixed intermittent Gold Mount battery communication
  • Fixed Absolute Frame Guide when values are outside the format limits
  • Fixed R3D timecode mismatch in camera array
  • Fixed stuck pixels in 7K 3:2 1.6x/1.8x format
  • Fixed inconsistent Iris values on lens swap
  • Improved V-RAPTOR XL DC-IN power handling
  • Improved RCP2 CDL control
  • Improved Cloud Upload File Types menu
  • Improved ND Stop Display Mode
  • Improved External Only Audio over SDI
  • Improved Network Static IP setup
  • Improved DC IN low voltage warning interface
How do we update firmware over USBC? Obviously can’t do it for the update that *provides* the function, but just curious for the next one. Will it show up as a drive on the desktop, then drag and drop? What’s the procedure here
Using Red Control App
Still unable to edit the FPS list, what am I doing wrong?
Hey Nick,
On the side screen press the top left FPS button, then bottom right you should see a "List" option. If it's showing up properly, from that menu you'll be able to select or deselect the FPS values you'd like to see or hide.
Hope this does the trick.
I think you can now update FW using a USB-C stick or drive connected directly to the camera as you would do to update using a media card.
As Andrew mentioned updating also works via the app regardless of how you connected it to the camera (wifi or USB / Ethernet).
Thanks Mikael! This is unrelated, but since you’re probably the most knowledgeable person on this topic, may I steal another moment of your time? For some reason, starting about 3 fw updates ago, my V-Raptor VV can no longer connect to Control or Control Pro over infrastructure mode. Ad-Hoc works just fine, no issue there. I’ve tried many different networks in different locations over infrastructure, all of them show “connected,” display the MAC and IP address, but won’t show up in the Control apps. Do you have any recommended troubleshooting steps, or is this probably an issue that would require sending the cam in to RED HQ?
Hello Ryan. You can dm me here or by email so we can look i to it. I can help make sure camera and device are indeed on the same network if you send me screenshots of the network settings on both sides….but if they are correct and it works fine in ad hoc it is possibly an issue on camera side …
