RED PRO Touch 7" LCD ( Hingeless )
Jarred Land
Fire Chief
Staff member
$2950
http://www.red.com/store/products/red-pro-touch-7-inch-lcd
ESTIMATED TO BEGIN SHIPPING IN FALL 2016
The RED® Pro Touch 7.0" LCD offers a high-definition viewing experience for recording and viewing footage on your DSMC® or DSMC2™ camera system. A 1920 × 1136 resolution display panel provides improved color accuracy, high pixel density (at 323 ppi), and 1000:1 contrast. It is also bright enough for operation in high ambient light. A robust, optically-bonded touchscreen provides the most intuitive way to navigate menus, adjust camera parameters, and review your .R3D clips directly out of the camera.
The lightweight display mounts to your BRAIN® or other 1/4-20 mounting surface and provides a LEMOconnection to connect to your camera. The RED Pro Touch 7.0" LCD is an ideal monitoring option for gimbals, cranes, and remote (away from the camera) viewing.
For DSMC2 shooters, use a DSMC2 LEMO Adaptor A in conjunction with the RED Pro Touch 7.0" LCD for convenient mounting options away from the DSMC2 camera BRAIN. For a more ergonomic monitoring solution when you’re on the move, see the DSMC2 RED Touch 7.0" LCD featuring a fully rotating and lay-flat hinge design.
[TABLE="class: specs, width: 100%"]
[TR="bgcolor: #888888"]
[TD]DIMENSIONS[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Height: 5.24 in. (133 mm)
Width: 7.28 in. (185 mm)
Depth: 1.22 in. (31 mm)
[/TD]
[/TR]
[TR="bgcolor: #AAAAAA"]
[TD]WEIGHT[/TD]
[TD="class: right, bgcolor: #CCCCCC"]1.10 lbs (549 g)[/TD]
[/TR]
[TD]MATERIAL[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Aluminum Alloy[/TD]
[/TR]
[TD]RESOLUTION[/TD]
[TD="class: right, bgcolor: #CCCCCC"]1920 × 1136[/TD]
[/TR]
[TD]PIXEL DENSITY[/TD]
[TD="class: right, bgcolor: #CCCCCC"]323 pixels per inch (ppi)[/TD]
[/TR]
[TD]REFRESH RATE[/TD]
[TD="class: right, bgcolor: #CCCCCC"]60 Hz[/TD]
[/TR]
[TD]RESPONSE TIME[/TD]
[TD="class: right, bgcolor: #CCCCCC"]23 ms (black to white)[/TD]
[/TR]
[TD]CONTRAST[/TD]
[TD="class: right, bgcolor: #CCCCCC"]1000:1[/TD]
[/TR]
[TD]BRIGHTNESS[/TD]
[TD="class: right, bgcolor: #CCCCCC"]350 cd/m2[/TD]
[/TR]
[TD]COLOR DEPTH[/TD]
[TD="class: right, bgcolor: #CCCCCC"]8-bit RGB, 4:4:4 progressive scan (16.7 million colors)[/TD]
[/TR]
[TD]COLORS[/TD]
[TD="class: right, bgcolor: #CCCCCC"]70% NTSC[/TD]
[/TR]
[TD]VIEWING ANGLE[/TD]
[TD="class: right, bgcolor: #CCCCCC"]± 85° all axes[/TD]
[/TR]
[TD]DISPLAY ORIENTATION[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Landscape, 180° rotation[/TD]
[/TR]
[TD]TOUCH[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Projected Capacitive (PCAP), multi-touch[/TD]
[/TR]
[TD]BRAIN CONNECTION[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Power and Communication via LCD/EVF cable[/TD]
[/TR]
[TD]MOUNTING[/TD]
[TD="class: right, bgcolor: #CCCCCC"]26x 1/4-20 mounting points
2x 3/8-16 mounting points
[/TD]
[/TR]
[TD]HOOD MOUNTING[/TD]
[TD="class: right, bgcolor: #CCCCCC"]M3x0.5 × 5 mm (max depth)[/TD]
[/TR]
[TD]BUTTONS[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Up, Down, User 1, User 2[/TD]
[/TR]
[TD]POWER CONSUMPTION[/TD]
[TD="class: right, bgcolor: #CCCCCC"]5.5 W (typical)[/TD]
[/TR]
[TD]OPERATING TEMPERATURE[/TD]
[TD="class: right, bgcolor: #CCCCCC"]0°C to 40°C (32°F to 104°F)[/TD]
[/TR]
[TD]STORAGE TEMPERATURE[/TD]
[TD="class: right, bgcolor: #CCCCCC"]–20°C to 50°C (–4°F to 122°F)[/TD]
[/TR]
[TD]OPERATING HUMIDITY[/TD]
[TD="class: right, bgcolor: #CCCCCC"]0% to 85%, non-condensing[/TD]
[/TR]
[TD]STORAGE HUMIDITY[/TD]
[/TR]
[TD]FIRMWARE REQUIREMENT[/TD]
[TD="class: right, bgcolor: #CCCCCC"]Compatible with all firmware v5.2.38 or later[/TD]
[/TR]
[/TABLE]
Back to the future, sort of. You're going to sell a boatload of these. Might even become your most popular version.
wow nice man!!!
my 5 cents - just do at least one 1/4 hole that is the center like 3/8
Yep, for noga arm/RED arm folks that would be nice. Likely could remove the 4 not centered 1/4"-20 below the 3/8"-16 and replace it with one centered 1/4"-20.
I guess I'm having a hard time understanding the difference between this and the old 7" red touch, as well as the dsmc2 7" red touch, other than its ability to fold, and attach without an extra arm.
There are people who have their displays on Noga Arms/RED Arms or whatever all day. Having a hung adds additional bulk and perhaps not the perfect rigging placement for some. For others they'll want the flexibility of being able to rig onto the camera.
RED is providing options for all sorts of rigging preferences here.
I'm a cable-less man myself lately.
You can get size reducer bushings for less than a dollar each and then you never have to worry about messing up the threads in your $3000 monitor.
