Scott Crawley
- Jul 30, 2009
OK, I'll play.
The part outlined In purple extends off of the dumb side of the camera. It contains ports or controls of some kind, though I'm not convinced they are BNC. What we can see looks more oval in shape.
It would definitely interfere with the regular side handle, but may be angled in such a way as to play well with the switchblade. This part may in fact be the reason why the switchblade was created. This question though, is why my mind is open to the idea that these are controls rather than connectors but that would be a departure from all of the Red designs we have seen thus far.
If you are correct and these ports do interfere with the switchblade, you then have a basis for the argument that this part is a companion to the new part with the "w"skull pictured on it. If that were the case it would be very limiting and if this is not a part the user can install I would say it is much too limiting. That is why I conclude that it will play well with switchblade.
i don't think it is as deep as you suggest. I believe the mount sits in that blue outlined space and sits flush with the front of the purple outlined portion.
The pins I presume do have spring to them just like all the others currently in use in the system. Yes, there is a new pin in the series, suggesting enhanced capabilities within new lens mounts. There may also be, as Jarek indicated, an additional female connector like the one we see on the back of the camera, below a similar but shorter row of pins.
[/QUOTE]
The guesses for the object below have to do a better job of explaining what the part outlined in purple is and where it would most logically go. I think it holds BNC connectors, outlined in orange. If that's true, wherever this thing goes, front or back, you'd think the connectors would be on the dumb side of the camera.
If it goes on the front of the camera (such that the BNCs are on the dumb side):
a) once cables were plugged in, it would make using the Switchblade difficult and would seem to preclude using the DSMC Side Handle altogether
b) you have to account for the large, open space outlined in blue. I'm assuming the green edge sits flush against whatever it attaches to. Based on where the pins are currently located behind the lens mount, this piece oriented in that position means the space in blue greatly exceeds the very thin lens mount and leaves the part outlined in purple sticking way out in the front of the camera.
c) assuming the green edge sits flush against what it's attached to, unless the black plastic piece that surrounds the pins is spring loaded, it doesn't seem to correspond to how current lens mounts attach. And, don't the mounts themselves only have 12 contacts? So, how would the 13th pin on this thing communicate with the mount?
