Brian Timmons
- Apr 29, 2007
- NJ
- www.britim-media.com
Test…
For the sake and craft of cinematography the most thorough and reliable means of anyone understanding the best ISO settings for their camera(s) of choice is to test.
800-1200 was normally fine for me with the RED One MX and I remember rating the original RED One anywhere from 250-400.
If I shoot slower motion at a lower resolution (3K or 2K on the RED One MX) I might drop the ISO to 640-400 to help minimize noise at the lower resolution and cropped sensor.
I still take this similar approach with both Komodo and Komodo X.
Still it is best to test to see how the highlights, shadow and noise behave based on the how you plan to shoot, the conditions you might encounter and the look you want.
The end result of that testing is your ISO number or range.
Even with film, a DP would not just dial in a film stocks written ASA (ISO) and call it day.
It was always treated as the manufacturer recommendation. A starting point.
It was common to re-rate a stock based on the look a DP wanted among other reasons.
Years ago I once had to re-rate a film stock from 200 to 160 based on a particular film lab (old times) processing the image slightly darker compared to another lab.
I can say that with some of the advancements in debayering and color science with RED Raw (ie IPP2) that footage going back to even the 1st RED One looks cleaner than the debayering that was available back 15+ years ago so this issue of rating is a bit of a moving target.
There were a few times I experimented with pushing original RED One footage to 800 or even 1600 ISO and thought it looked a bit better (though not perfect ) than I remember it did back in 2009.
Brian Timmons
BRITIM/MEDIA
Brian Timmons
BRITIM/MEDIA
