- Thread starter
- #121
Jannard
Red Leader
- Dec 28, 2006
Additions to RED one as well as new RED hardware.
1/ Remote head RED with fiber link to body. Cage system for lens and camera to allow easy rigging of front heavy camera and lens.
2/ Mini RED with CF that records uncompressed (to keep camera mass down?) for use in stunts. Industrial cams incorporate a G meter to activate recording. Only needs to record min 60 seconds uncompressed.
3/ Baby RED with 35mm size sensor in EX1 form factor with integrated 5x zoom, power zoom, manual focus.
Could do away with some features (HDSDI outputs) to keep it small.
4/ 14 to 17 inch monitor 1920x1080 pixels. Include 3D viewing option.
5/ RED one simultaneous recording via two CF card slots.
6/ RED one Simultaneous recording using CF and SATA.
7/ RED one File exchange between CF and SATA
8/ RED one User variable scaling frame rate, let us decide what res is and isn't acceptable at particular frame rates.
9/ CAC chromatic aberration compensation when using 2/3 inch lenses
10/ RED one vertical filter slot in front of sensor, for ND or CC filter. May be possible to squeeze 2 ND and clear on one 2 x 4 inch slide. This could also be the IR filter.
and/or some other way of reducing sensitivity.
11/ Factory controlled calibrated test 4k frame/s in camera to aid monitor set-up and QA trouble shooting.
12/ Video village Fiber link with HDMI HDSDI audio time code ect in/out. Breakout box for same.
13/ RED player, a la Panasonic P2 player but with push button activation of user installable LUTs. High quality screen with 1:1 Basic VTR controls. NO erase function!
14/ RED TV portable recorder
Compact CF recorder with with HDSDI input and conversion to RED codec.
10 bit recording of 4:2:2 or 4:4:4
Allows recording of any HDSDI signal. ie use of HDSDI output from EX1, Z7 F900R or 60p output from HDC 1500 F23 or Genesis or 4:4:4 too.
A replacement for the SRW1 (for short form work at least)
Easy integration into RED workflow, easy for producers to understand.
or licence RED codec to the guys already building a CF recorder that has XDCAM HD codec.
15/ RED TV compact camcorder. A 3K 16mm size single sensor sampled to 1920 x1080. 16x lens.
EX1 or better form factor with RED2k /HDSDI recording.
16/ Option slot.
ie for a GPS tracker. These assemblies are down to $100 and now have integration to Google maps. Size of a pack of gum. They could automatically download their file to CF before ejection of the CF or at the end of the clip. Current trackers use USB.
17/ GPS read and search integrated into edit software. No one is doing this.
18/ Rate sensors built into camera for roll, az and el recorded as meta data that also can be read by edit or sfx software to stabilise hand held and other uses.
19/ RED one Mechanical contact to enable integration with numerous remote systems.
20/ Remote menue operation that is expandable to operate or control user configurable accessory ports.
21/ 8K sensor for Imax.
22/ Self resetting fuse to protect against reverse polarity or spikes.
Over current protection for accessory DC outputs if it doesn't already have it?
23/ The menue display and operation at the rear of the camera is a novel position with a battery behind it. Duplicate it on left or right hand side.
Familiar ideas list.. just gets longer!
Mike Brennan
Mike... you have just described our $350,000 model that is in development!
Jim
