Gunleik Groven
REDuser Sponsor
People will shoot with anamorphic lenses FOREVER.
A FF 4:3 sensor would be very, very smart.
I would not mind one...
Maybe Alexa would score higher than Dragon in some areas but its resolution (and size) make it unsuitable for a lot of serious print work.
2K is not enough for most stills work, so Alexa would not work.
No, it's 50% greater (double the pixels = 50% gain in resolution).a D800 still is twice the Dragon.
May I suggest to all DPs who get push back on using Dragons on their shoots, please make a PDF of the test results and print it out. Keep it close to you and show all parties who question you.
Simple. And hopefully effective.
What's the point? Dragon is the only motion camera they have tested so far. You might aswel show them Dragon's specs
100% Disagree.
Because DPs will understand the significance based on the technical information. Color fidelity, skin tones, etc. has been perceived as "not good enough" for many DPs with Red One MX & Epic MX.
It's VERY important IMO to get folks to open their minds to the fact that Dragon is an entirely new sensor. It's not just "the RED sensor that does 6K". It's a new "film stock". 6K is just a huge bonus - if Dragon was only 3.8K UHD - I would still choose it ANY day over MX at 5K.
It needs to be evaluated from scratch by cinematographers and photographers.
Hopefully, information like this will help open a few closed minds. People should NOT be coming to conclusions and passing judgement on Dragon or ANY other camera just based on tests, examples and posts on REDUSER and CML. Not saying posts, tests and examples on REDUSER and CML are bad - the opposite in fact - they help educate. But the best way to filter out "marketing", "fanboys" and filter out "haters" - is to show some technical evaluations from camera agnostic sources.
Also I want to give a shout out to Graeme for his color science voodoo......
He is an evil genius.....
I just had to point out in a discussion on LinkedIn (That Matt Hayslett started) to a cinematographer that wasn't very impressed that this camera could do 90 frames pr second of high res stills, and that was the reason RED was tested and bot an Alexa, as he wasn't aware of the fact that the dragon could do this.
We still have some way to go with some people
