utku sonmezer
Active member
hey tonaci what kind of battery plate is that? really nice and solid way of mounting. Is it custom made? where did you get it?
Thanks Ketch! Now thats interesting about not using a lens support. Epic X has a Ti mount also, but the body that it bolts onto dosen't have the same structural strength as the M. I wonder if the torque transmitted from a lens of this mass, through the mount and to the camera body will be just too much to use it without support on the X.
I have the 18-85 and wouldn't use it on any camera without support, I don't think that Ketch is doing that either. The torque on the actual mount would be much greater than 10lbs.
He he, a fabulous lens, even put the Titanium strength to the test with no support... But seriously, a Fantastic Lens, no vignetting good all the way, Such an insane lens on the EPIC!!
Balance, oh well, Epic 5lb, RPZ 18-85 10LB...
Just one question... Why! are RED lenses so damn big and heavy! . Is there a reason.
While the Ti mount may hold up I can tell you that the lens mount won't. It will flex and throw off the back focus or if the pans are fast it will bend.Yes, I do recommend for every one to use proper support with any lens andy time is possible, BUT, I did and will continue to use the RPZ 18-85mm and other heavy long lenses with NO SUPPORT,
as I am super confident of the Titanium mount capacity to hold such weight for the short burst I'll be using it for, of course I also KNOW GLASS, so I know which glass is built good in off to sustain such burden
on its mount and which ones can't, believe me even at 10LB and by iota length, the RPZ 18-5mm CAN...
But again always use caution and your head when using any Professional gear for each individual job, no piece of gear can or should be use the same for every Job or situation,
but the situation and job should demand what to use as accessory of your camera and or lenses...![]()
Lightweight, fast, cheap.
Pick two. :biggrin5:
Oh, Hey! I was there for that! We were at DC Camera with Erich Roland.
I've seen it happen many times. The lens support is mainly to support the lens as the name suggests - otherwise it would be called "camera mount support"
You must admit Ketch you do get carried away sometimes:thumbup1:
Is this lens too big for run and gun or would the 17-50 plus RPP 85 be better?
