- Banned
- #81
Can't Wait to use on Set. I posted a similar concept nearly 2 years ago. http://reduser.net/forum/showthread.php?t=10200
Go RED!
Go RED!
Here is the PRORES, 16BIT TIFF and DNxHD module... works great NOW and doesnt turn a RAW Digital CINEMA camera into a video recorder
Tim,
what is that?
Here is the PRORES, 16BIT TIFF and DNxHD module... works great NOW and doesnt turn a RAW Digital CINEMA camera into a video recorder:closedeyes:
Normal H.264 would group together a lot of frames for the best compression (one reason it's harder to edit) so I'd think it would have a very significant delay. I would not expect this to be good for focus pulling, unless they are using some less-compressed subset of H.264.
Here's one "low latency" MPEG4 encoder, the best it can do is 0.3 second delay which seems like a long time if you're trying to keep the focus on track.
http://www.fujitsu.com/downloads/COMP/ffna/video/ip-9500_datasheet.pdf
I posted this in the other thread, seems more relevant here now:
On the 4th page here http://205.186.140.43/epic.html where it lists the "easy as" steps, #2 says "Easy to Post; Native Realtime support from most popular applications... including the free RedCine-X application. 4k Playback, grading and transcode with RED Rocket™™™™."
Does this mean the rocket can't do Epic's 5k? Any clarification would be helpful.
Thoughts?
RED Rocket™...
Oh, I think it will handle 5K just fine... and Im pretty sure Jim confirmed that somehwhere... remember the RR will debayer the 5K to 4K - dont see why it would not support 5K 6K 9K and 28K acceleration is my thoughts.
I thought that was the word as well, but since everything is subject to change, a clarification on the language used is needed.
I can see using it MUCH of the time in run & gun situations where we can't connect a cabled monitor. Can't wait to see or hear more about it.
I sure hope this is a smaller/thin module as I can see using it MUCH of the time in run & gun situations where we can't connect a cabled monitor. Can't wait to see or hear more about it.
Can anyone confirm this? Most of the time I do run and gun stuff I am not under a wifi signal.
