Antoine Baumann
I'm trying to unlock the Red Touch Screen by touching the lock icon, but nothing happen. Is there an other way to unlock it?
Is there a way to disable the lock function permanently? It is the number one problem I have with assistants using the camera on a rental. the screen gets locked by accident, they freak out and cannot unlock it.
+1
The lock function on RED's touch screen is purely idiotic. This NEEDS to be a hardware switch. The touch screen does not always function properly. I've had this issue too many times on set and though it can usually be solved (after multiple attempts and finger holding for 20+ sec) it is nevertheless an absolute pain when encountered in the heat of battle.
Trent,
I'm really glad to hear that this problem might get fixed. For my particular camera and screen the issue is way better now than it was early on, but I still dread touching that upper right hand corner of the screen.
I'm sure the ability to lock the menu is of use sometimes with a big crew. For myself, usually operating alone filming natural history, it has just been trouble. It is easy to accidentally lock, which is indeed only annoying. My emotional response does gets a bit stronger when it then mysteriously refuses to unlock, despite the tenderest of touch and stroke : )
How are you dead in the water? If the LCD is locked and you are unable to unlock it, you can force it unlocked by resetting to factory defaults by holding down the power button for 15 seconds on boot.has this been fixed yet? we are dead in the water on a documentary because of this issue.
