Savannah Miller
- Jan 13, 2018
Naw, we can work with R3D fine on a fast system. I draw the line at 6K and 8K, because things start falling apart quickly there. But 4K & 5K Raw are fine. If we use ProRes 444, I prefer to make it myself just to make absolutely sure it's decoded and debayered correctly and the DP's original settings are retained. I'm generally not a fan of 422 or 422HQ when I can avoid it.
VFX workflows are more complex, but trust me, they're not using Raw there, either. I generally only see DPX and EXR being used there, but again, the settings have to be just right, and it's a good idea to give them a reasonable LUT as the final layer so they can see the composite in context. On tight schedules (and small budgets), ProRes 444 can work fine, and I've seen this done all the time for quick-turnaround TV projects.
For places I've worked at it's usually DPX that is either delivered from the client (when using something other than Prores) or for Prores shows, it's converted by us in-house directly using EDL and Camera Reels. Then it's done in/out in DPX and then those DPX files are converted back to Prores for deliverables.
EXR is typically used when shots are worked on by multiple people as an intermediate format for precomposites.
Prores 4:4:4 generally works fine with very few issues (vfx-wise). If cameras have some internal sharpening settings, maybe they can cause some artifacting during keying, but generally otherwise it's usually not a problem.
