I’m considering a Komodo, but I will need a true EVF. Don’t have a grasp on the red ecosystem, but is there a “pogo cable” that will allow for an EVF to be mounted properly?
To my knowledge, you cannot use one of the EVFs designed for previous Red DSMC systems.
You can use any EVF designed to take a signal over SDI. Zacuto has a good track record with these, Portkeys is a newer entrant, not sure if Alphatron still makes one...
I have a Zacuto Kameleon EVF and I’ve been pretty happy with it overall. Cabling can be a bit of pain but that seems true with every aftermarket EVF and even some OEM EVFs.
On the Komodo, I believe there is only the single SDI output and wireless monitoring options through the app. Someone else can chime in here but I think the top pogo only provides "run / stop" control and there is no monitor out possible from that connection.
