Ryan Sauve
- Oct 21, 2011
- Calgary, AB
- www.t2iforum.com
So "Vista" is the next sensor then?
I think the Vista Vision is approx two Dragon sensors stacked vertically. So not new sensor "tech", just more Dragon pixels to cover Full Frame/VV/4:3.
Vista Vision is the equivalent to Full Frame...
the active film area of VV is 36 wide but not 24 high - IIRC it is 18 high, so it does not match still FF 35... (please correct this if wrong)
For starters Matt, I think your math is off - putting 2 Dragons vertical and side by side would create a roughly 6K by 6K square-ish target.
In any case, assuming the manufacturing process follows "typical" methodology, (and assuming RED is happy with the per photo site metrics on Dragon) changing the wafer cutting pattern is the likely choice. FWIW, one of the typical impediments to developing larger sensors - especially high performance designs - is getting a decent yield of chips with 100% good pixels.
Cheers - #19
VistaVision is slightly larger than FF35..
ISo I don't believe it's two sensors stacked, more likely a larger cut out of the sensor wafer.
hmmmm, check this out... http://en.wikipedia.org/wiki/VistaVision
all we need to cover is the active film area... not the entire film strip...
You're thinking in terms of film though.. This is Digital so slightly different.
why would it be ?
digital sensors match the physical dimensions of film formats so that FOV/crop factor etc remains the same with given lenses... there is no difference. it's simply the physical size of the active recording area.
5D is digital FF35 sensor in exact same dimensions as the still film format: 36mmx24mm.
if active area of VV is 36 wide then u can use the format with all FF lenses, otherwise (if larger) u would need to get medium format glass to fully cover...
