Koray Birand
- Oct 12, 2011
- London / Istanbul
- www.koraybirand.co.uk
Dan has contacted me, and he is helping me. Thanks everybody for your feedbacks.
what's the best HDMMI to SDI converter? I tried once on set the Black magic design and it was impossible tom make it work with the parallinx. Any advise?
Thanks,
Thanks,
Atomos Connect?
The Black Magic converters work fine with the Paralinx. Older "Mini Converters" won't pass some of the higher-frequency 1080p signals like 1080p59.94/60, but that's a camera setting. The BMD "Battery Converter" will pass anything Epic will put out. I've had no problems with either device working with the Paralinx.
Yea, Atomos Connect works good.
That's not normal Koray - if you can email us at info@paralinx.net we can set up an RMA for you. Have you tried different hdmi cables on both sides? What camera are you using and what monitor? Either way that is not normal and we will help you get it straightened out.
Nice. How are you powering the transmitter?
The Jetpack has a 5v USB that can power it.
http://www.reduser.net/forum/showthread.php?92402-The-missing-link-Switronix-Jetpack
http://www.switronix.com/products?pa...category_id=51
