OFFHOLLYWOOD OMOD Modules for RED WEAPON
Oh so your saying I can get the element technica plate to power the omod with no cables, and you are also releasing your own battery plates. I didn't realize we could use other plates with no cables. Awesome.
Alrighty then. I'm going to get the ET plate now and order an omod as soon as I can. I really wish I would have signed up for the early adopter program. I almost did, came so close. I don't suppose there is ANY way to still get in on that?
Edit: if your battery plate has a built in short term battery for hot swapping I'll be getting that and selling the ET plate. But hopefully this is in the other part of the OMOD body. I know u mentioned it before and it's a gaping hole in the ecosystem now...
So to recap, when it comes to V-lock, our Weapon options are: (please correct if wrong)
1. Current ET V-lock, which WILL power both upcoming OMODs and Weapon, though the Top Handle won't fit. (also- is the ET now able to supply battery info to brain?) - $900
2. Red DSMC2 V-lock Expander - no ETA - $1900 (does this also power an OMOD sandwiched between brain and module?
3. Forthcoming OMOD battery plate.
4. ?
I'm already over budget with my Scarlet-W, and since it will be limited to studio use for awhile, I think I'll just have to accept the fact that I'll be stuck running on AC until the OMOD battery plate is ready. These $1k-$2k temp vmount solutions will break me. :)
Speaking of which, any idea of what the OMOD battery plate will retail for?
ET V-Lock and Top Handle go together with PAGlink batteries (about 1/2" margin even).
There are other low-profile V-mounts that should work.
REDBRICK is to long (or high) indeed.
I don't know yet as final design is not done. It has an extra SDI - because if you are paying attention you know we have video coming off of the interface on the back of the OMOD - which feeds video to any OMOD TX video transmitter - so, when you don't have an OMOD TX on the OMOD - that signal goes into the OMOD Battery Module and gives you another SDI.
So, on the lower cost modules like POE - that have only one SDI and one HDMI - with an OMOD Battery Module - you get another cloned SDI.
You mentioned earlier some sort of earlier adopter program. Is it too late to be part of that?
Yes - the OMOD Early Adopter program is closed. That was fast and furious during IBC.
But since you are just across the river - you will be able to come over to Brooklyn and play with some soon enough :)
I definitely want to try some out thats for sure .
4. ?
There is a W.C. solution...
