Thomas Ramsey
I know Switronix is coming out with their new slims, but is there any other economical alternatives for v-mount batteries that are rated for RED? Slim ones?
The GlobalMediaPros look great, and it could save me a few hundred bucks on a dual battery/charger set up over Switronix. Is this "RED approved" if such thing exists?
Can you use v-mount batteries with the DSMC Battery Belt Clip or is it with Red Brick only.
The globalmediapros are great but we have to wait to see if they will fit in the Vlock expander. Personally I don't think they will.
It's about the distance between the rail and the connection ports block on the module. The battery could be too large for it.Quick question, why won't they fit? Are they too large?I was thinking of getting the Bebop v150s and those dimensions are 144x94x58mm vs. Global Media Pro 160h which is 150x102x49mm. Bebop is 6mm shorter and 8mm less on width. Do you guys think this will fit the V-Locks on the Scarlet-W I/O?
Maybe someone from RED could answer beforehand? I would love to know options.
sale going on at B&H on the switronix batteries. Plus i REALLY like the CS guys at Switronix, super helpful and quick at fixing/replacing batteries. and they are in New York so makes things easy for me
ah, now i wonder who can say which ones wont fit!The maximum width can be 100.6mm as long as the bottom edges have AT LEAST a 9.70mm radius. Any larger width or smaller radius will not engage properly as it will bump against the I/O portion of the module.
