Les Hillis
- Oct 24, 2010
I don't see any difference between 40C and 48C.
The only point to change the Fan temp -> Calibration temp is to have a quieter Fan (if set to 46C) or a cooler camera and electronics (if set to 40C).
Pat
That's what I found too.
Any difference in image quality I saw across the range of available temps was so subtle (if there at all) it was never likely to be noticeable beneath all the other image variables being applied/dealt with.
I think it's mostly about setting your target temp to suit your ambient environment, with something in the mid 40's often being recommended as the sweet spot because it gives you most leeway up or down (warmer or cooler) across the range of temps available.
In some cases during the height of summer, I find the fans still running full blast to keep the temp at 46°C, while in winter it just makes the camera take longer to get up into the green after starting up.
The different RED sensors (MX, Dragon, Helium etc.) are designed to run at slightly different temps, but they're all still within the same range of temps available in camera.
Here's another discussion on the topic - http://www.reduser.net/forum/showthread.php?161303-Ideal-temperature-35C-40C-42C
