Antony Newman
In earlier Monstro sensor testing, SENSOR NOISE vs SENSOR TEMP was compared :
+) The MONSTRO sensor has minimal noise AT or HOTTER than the Target Temperature that the sensor was Calibrated at.
05 - 43 44 45 46 - 1024 pix
+) Of the ADAPTIVE FAN algorithms currently on offer - 'ADAPTIVE' is the only option that is stable (the other options often have a mind of their own and should be avoided).
+) The 'ADAPTIVE' algorithm 'wakes up' as it PASSES through a specific temperature.
If your target temperature is 44 deg C -> this means that Calibration temperature will fluctuate AROUND 44 deg C.
The problem with this:
+) 1 deg BELOW Calibration (43c) - there is NOISE
+) 1 deg ABOVE Calibration (45c) - there is NO Noise.
To MINIMISE NOISE (for my sensor)
+) Calibrate the sensor at 43,44 or (for Audio) 46 deg C - using 'Adaptive' Fan Mode
+) Change the Target Temperature to 44,45 , or (For Audio) 47 deg <- ie 1 deg C hotter.
AJ
05 - 43 44 45 46 - 1024 pix +) Of the ADAPTIVE FAN algorithms currently on offer - 'ADAPTIVE' is the only option that is stable (the other options often have a mind of their own and should be avoided).
AJ
