Jance Allen
- Jan 15, 2007
That would be a cool feature!
Hi Jance,
A couple of users have had this problem.
This is likely to do with the path to the footage vs. the path to the aliases.
Hi Craig!
Can Monkey Extract auto-select between Edgecode and TOD when pulling selects?
Any answer on this?
How do I go about changing the font size of the burn in. There doesn't seem to be an option to do so. A lot of editors want the smaller fonts.
Hi there,
I have an issue when trying to import the xml re-link file that monkey makes. It opens fine if I de-select 'audio/video effects' but hangs on 80% loading when its checked. I really need video effects to work, so any suggestions would be much appreciated.
Here's my workflow specs:
1. Flattened all video layers in FCP 6 > Export XML
2. Rendered XML in Monkey using Quicktime ProRes & time of day setting. No issues.
3. Import xml re-link file into FCP.
thanks for your help
((a)
Have you guys seen a improvement of bringing in DPX files to Color without relinking all the media again? I remember you all saying it was because of the FCP XML, any luck with FCP 7/COLOR 1.5?
Yes, It can,.. it will try to match your primary time reference first and fall back to the other if it can't find a match.
It will list all the clips that needed to use the alternate time reference after matching so you can see what is going on.
Thanks for the info - just to be clear, we may have at online from an EDL or FCPXML some clips with the TOD TC (vast majority) and some with edgecode (render error which is way too late to correct). Monkey will handle it?
Hi, I have an question for the way to rendering.
I know Monkey Extract can use distributed rendering with Apple Qmaster.
I want to know the speed of it.
For example, 4K R3D to 2K dpx files.
Please tell me the instances about yours.
Additionally, I want to know the example information how many machines do you use?
Hi There,
Monkey Extract uses Redline (from Red Alert) to render footage.
This is the same when using QMaster.
In terms of raw Render Speed you will get the same output potential as if you were running Red Rushes on each box (although with Monkey Extract you need to render less footage) since you will typically be running one redline instance per CPU core on each mac.
Render speed on a render farm is typically limited by your IO capability and/or network bandwidth rather than how many CPUs you can throw at the job since each computer is usually sharing a network connection to shared source data and also to your final output destination... we use a fibre-attached RAID here for this.
I'm not sure how useful it is to to compare speeds to what we get here at Rubber Monkey since render speed with a render farm depends on your entire hardware infrastructure... not just the raw render capability of each box. The render settings you use in Monkey Extract make an enormous difference as well.
The best way is for you to try it yourself.
If you send me an email at support@rubbermonkey.co.nz I will send you a full featured QMaster trial license and you can see how well it works for you.
Cheers
Craig
Thank you for your reply. As you said, I knew that render speed depended on circumstance. But I couldn't try it because I thought that I needed Qmaster on each Mac.You taught me, Monkey with Redline could use it instead of Qmaster.So, I will try it.If I need, I may request you sending trial license.Then, please cooperate.
Sincerely
Yes
If you need a full trial version to test for yourself, send me an email at support@rubbermonkey.co.nz and I'll sort one out for you.
Cheers
Craig
