Mike Finegan
- Feb 9, 2013
I am shooting on Scarlet and recently made the switch from Canon EF L series zooms to Primes (just Rokinon).
Did a lens test using the print it yourself chart at:
http://www.graphics.cornell.edu/~westin/misc/res-chart.html
Obviously the higher DPI the printer the more usable.
I discovered that at max spatial resolution - namely 4K WS 24fps - 5:1 compression, the image displayed on the monitor is distinctly sharper than what is actually recorded.
Granted 'visually lossless' depends on the content and distance, but it is big enough to cause me concern. Looks like 600 lines per screen height versus well over 1000.
No this is not scientific calibration - if that exists I am interested!
For Scarlet Dragon - it does not change much - according to the media guide 5K WS can only go down to 7:1, 4K WS is same as above 5:1. Seems only Epic Dragon gets big boost from minimag in that regard.
For Epic - 5K 24fps is 3:1
For Dragon - 6K WS 24fps is 4:1; 5K WS 24 fps is 3:1
Dragon with minimag - 6K 24fps - 4:1; 5K 24 fps is 3:1
So for my budget ($10k upgrade to Epic) seems that Epic is best choice for highest overall quality. Obviously less dynamic range than either Dragon, but extended range is mostly highlights.
Dragon, Epic Dragon, Weapon should all provide 'big screen' detail.
And before you say 'just shoot that scarlet'
I am. Just have gotten some feedback about being soft from directors on occasion. Suspect that won't change much even using primes.
Just echoing some of the tradeoffs, from my perspective.
