Mike P.
Isn't the next MacOS version supposed to massively increase support for eGPUs?
With this announcement, all of a sudden the MacBook is not that attractive anymore, in the sense that down the line there will probably be no way to plug any of these in via an enclosure by the looks of it...
Since you work with PP why all the hussle with a macbook.
The MSI GS65 is by no means a bad laptop and it has GTX1070 onboard and you can hook up any eGPU you want over TB3.
Compared with a similar speced MacBook it's about $ 1.200 cheaper
Operating System Windows 10 Pro x64-bit
CPU Intel Core i7-8750H Six Core Processor (9MB Cache, 2.2GHz-4.1GHz) 45W
Screen 15.6" Full HD Anti-Glare Wide View Angle 144Hz 7ms 72% NTSC (1920 x 1080)
Memory 32GB DDR4 2400MHz
Storage 2TB NVMe Solid State Drive
Graphics Card NVIDIA GeForce GTX 1070 Video Memory 8GB GDDR5
MSI $ 3.200 vs. $ 4.400 MacBookPro
https://www.newegg.com/Product/Product.aspx?item=9SIA65C78Z2359
Seen the MSI stuff, spec-wise great, but I want a little bit more juice out of my machine's display.
If not the MacBook, then XPS 15 it is, or that new Lenovo P1, it looks hot.....if it ships kinda soon, which I doubt. As far as the XPS goes, there's slightly higher deviations in accuracy for some colors and a little lower gamut coverage but I'll gain the ability to work better in Premiere Pro + eGPU capabilities down the line. Besides, based on everyone's valuable input I've read so far on this thread, considering all those panels are driven by 8-bit engines (which I actually wasn't aware of) + odd toe curves etc. I realized I should stop obsessing over crazy color accuracy!
Haven’t seen any benches yet of the RTX in Resolve. Have you?
One huge strike against most all PC notebooks is the single TB3 port. That and only one or two on the market have a screen even worth considering if you need to do any real graphics work. Having a GTX1070 GPU does help a bit for some things, not all and as soon as you decide to pair it with a powerful eGPU setup then you’re out of luck attaching performance storage or other add-ons. MSI makes decent notebooks, but they haven’t figured out how to make one with a decent screen. The Gigabyte Aero isn’t bad at all, my issue is with the lackluster I/O. And saving $450 over a MacBook Pro seems more like losing money when the MacBook Pro gives you 4 x TB3 offering up way more connectivity and expansion possibilities. It does have a Gen 2 USB 3.1 at least... That kinda helps...
Look at the new Lenovo P1. Step in the right direction.
How about this one:
Gigabyte 15.6" Aero 15X v8-BK4K4P Premium Gaming and Business Laptop PC
• 8th Generation Coffee Lake Intel Core i7-8750H (2.2GHz upto 4.1GHz, 6 cores, 9 MB SmartCache) Processor
• NVIDIA GeForce GTX 1070 GDDR5 8GB Graphics Card
• 15.6" Thin Bezel UHD Adobe RGB 100% Pantone X-Rite 3840x2160 IPS anti-glare display LCD
• LAN: 1 x 10/100/1000 Mb/s Gigabit Ethernet (RJ45), 802.11ac; Dual-Band and Bluetooth 4.2
• 32GB DDR4 SDRAM Memory
• 2TB PCIe SSD (Solid State Drive)
• Windows 10 Professional (Win 10 Pro)
• HD Web Camera
• No Optical Drive
• 1 x Thunderbolt 3, 1 x USB 3.1 Gen 2 Type-A, 2 x USB 3.1 Gen 1 Type-A, 1 x Mini DisplayPort 1.4, 1 x HDMI 2.0, 2 x Integrated Speaker, 1 x Integrated Microphone, 1 x 1/8" (3.5 mm), Headphone/Microphone Combo Jack
• Gigabyte Fusion Per Key RGB Keyboard
• 94.24Wh 10hrs Long Battery
• Dimensions : 356.4(W) x 250(D) x 18.9(H) mm
• Weight: 2 kg.
$ 3.950, still $ 450 less than a MacBookPro and a 4k screen with 100% Adobe RGB.
With a descent codec you have to be a real pixel peeper to see banding.
https://www.gigabyte.com/us/Laptop/AERO-15X--i7-8750H#sp
Absolutely, dual thunderbolt ports for the win!
There's also that new HP ZBOOK STUDIO G5 which advertises 100% Adobe RGB with 1 billion colors on its Dreamcolor display and I believe it, considering it's driven by a Quadro card, which to my knowledge outputs 10-bit color. I haven't seen any measurements of the actual gamut produced though, but Dreamcolor technology has a good reputation so there shouldn't be any major discrepancies. It also comes with dual thunderbolt 3 ports so it's pretty attractive, it's very similar to the Lenovo P1.
The Lenovo P1 does look promising. As was said above, Lenovo has the best keyboards. They also have some of the worst touchpads. You get their little trackpoint pencil-eraser mouse thingy which is actually handy at times, but only because their touchpad is so bad.
I’ve used the ZBook G5 a bit, and it would probably be my current choice if I were getting a PC notebook. I’ve mentioned my Dell on here a couple times. I’m not under NDA, but had not been specific about it since they’re not out in the wild yet. They might be now... And they are shipping with the Alienware label. I’m running a Dell Precision with the new 6-core i9 CPU, 32GB RAM and Quadro P5000 GPU (overpriced GTX1070M equivalent). It’s identical to the new Alienware 15, but has Quadro instead of GTX1080 GPU and no colored LED lighting. Still only one Thunderbolt 3 port. Given the choice, I would take the Alienware, but sometimes you get what you get when dealing with certain clients and corporate partnerships. I had high hopes for it, but the MacBook Pro outperforms it in every way other than a few GPU related tasks. The Dell has better polygon/ performance and supports CUDA. MacBook Pro GPU is superior for pixel/texture throughput. Technically the Quadro should be better for computational work, but they’re pretty much dead even with the OpenCL testing I’ve done. Can’t compare CUDA or Metal...
As for 10bit color on the Quadros or other supporting GPUs. It’s still hit or miss in terms of support. The 2016 and now 2018 MacBook Pro support 10bit as well. I can enable it in a Metal or OpenGL full-screen view. I don’t know of any apps that are using it. Just as no one seems to use the 10bit ability on some of the GeForce cards that offer it. And I know Resolve and some other apps like Photoshop will offer some support to some specific GPU models.
Are you using the new Precision 7730? It has dual TB3 and quadro p5200
To be honest, I’m not sure which model it is as there’s no Precision label or model number referenced. It’s a 15” (3840x2160) screen, single TB3 port. Has 32GB 2666MHz RAM, can take more — 64GB for sure, possibly 128GB, with a Xeon CPU and 2400MHz ECC memory. This unit has the i9-8950HK CPU (2.9GHz 6-core) that everyone is using, same as in the top end MacBook Pro. P5000 GPU with 8GB. Wish it had the P5200 as that’s the GTX1080 equivalent. I didn’t get to select the configuration completely, it’s a corporate partnership deal and I got the system a little over a month ago and while I can use it or do whatever, it’s basically a corporate leased unit via a client I do a lot of consulting for. It came in a plain brown Dell box with just the power adapter and recovery disc. The client had already placed their asset tag on the base of the unit. Hard drive was wiped bare, I had to do a fresh Windows install, which I would’ve done anyway.
EDIT> Oh, it also has a fingerprint reader and the system-wide encryption.
