Daniel Stilling
- Dec 14, 2009
- US, Denmark
- www.danieldp.com
Sorry but your definition of "close " ifs different than mine. 20mm(raven)/25mm(S35) width is 80% (or 75% depending which way you are calculating) If that's "very close".......
The diagonal is even more spread out(because of the roughly 2:1 aspect ratio of the Raven vs 3:2 or 4:3 aspect ratio of the S35) 22mm diagonal Raven vs 30mm diagonal S35. If that's "very close" to you.... That's fine- your definition ;-)
And it will work fine- with the right lenses ..... just pick them carefully....
I understand that your job is scrutinizing lenses, mounts, pixels and so much more, and that is absolutely excellent that you do that, and I mean it.
But just as with lenses when you check them on charts and find out the technical differences between them, also this sensor size issue is plagued with the same dichotomy: one thing is to sit down and calculate numbers on a piece of paper (or on a screen) and another is to use the tools day in, day out. With lenses, realistically you might find huge differences on the bench, but in real life, unless you stress them, and that's where the good lenses shine, you might not find any remarkable difference between a cheap and an expensive one.
The same is this sensor size issue: 20% sounds like a lot, but in real practical use, you will never know the difference. It's not like super 16 where you'll need an 8mm lens to get wides. Not at all. Just move your camera back a few inches and you'll be OK. That is my assessment of "not that different".
