George Hupka
Active member
- Jul 4, 2008
Okay, I got a Redmag reader in late yesterday, so finally I'm able to do a bit of experimenting.
Started by reinstalling all firmware to the current beta build, which is required for Pro I/O operation.
First test was from a 442 line level to the Pro I/O - inputs set for Line In, 0VU. The return via XLR-5 is still very hissy. However, the playback from the card is fine.
Second test, I switched the 442 output to mic level and set the Pro I/O inputs to Balanced. Exact same results - hissy monitor but the recording is good.
Thought I'd go right to the torture test and pulled out the Sennheiser G3's (Sorry Marc!) On the monitor out, in addition to the hiss I had experienced with the the mixer, there was also the "pulsing gain" effect that I'd run into before. However, this time the recording seems to be clean - noise is what I would expect to hear from the G3's.
So, I would have to say at this point it looks like the Pro I/O is good for recording, but the noisy return makes it impossible for a sound person to know for sure whether the camera is recording a clean signal. That would be a pretty big drawback for anyone hoping to go single-system without a safety net.... But if you always do a backup recording from the mixer, now at least things seem to be a lot more stable.
If you are hoping to "run and gun" without a sound person... personally I wouldn't do it without a rock-solid headphone monitor, which now seems to be the biggest issue. The hiss that's coming back from mine would make it very difficult for me to hear actual audio problems in the field - sound person can monitor the mixer, but if I'm shooting I can't! (And as there are no tools designed into the Epic to adjust audio in a "run and gun" situation, I would suggest that you are using the wrong camera for the job....)
My next tests will be back through the "brain" inputs to see if those are any better (firmware improvements?) or if it's just the Pro I/O.
