yves d
Hi guys, what are the r/s cable and the RED record trigger cable?
I have had emails back and forth with things I have added on like the extra motor cable and now haven heard back form them for a bit. I would like to use my CC so I requested a form as some have stated above so I hope to hear back from them to get this locked in.
Anyone else experiencing this? Sounds like they are a little backed up.
I remember reading where you mentioned your target was about a thousand sign ups but clearly it doesn't seem Tilta had that much expectation otherwise I guess they would have been better prepared for all this and given more realistic cut off. I guess next time they will have more confidence in your estimations, only hopes this bottle neck don't spill over into their supply /distribution execution. Kudos and thanks for all the efforts you put into all these.Payment date extended until this coming Saturday, July 1st.
Played with it yesterday in Burbank. Moved an super stiff zoom without a problem. It'll move just about any lens save for the stiffest vintage glass on a cold day. Way stronger than DJI / Redrock. It was a proto and they're working out kinks before shipping (tighter tolerance on handgrip control, better battery latch, etc). Other notes: motor was silent. Speed on a full speed rack was good. Response / lag excellent. Built quality - superb. No steppiness at all. What also surprised me was how good the build quality was for the 15/19 handgrip bracket. I didn't order one because I have a Wooden Camera bracket but after seeing this, I'll probably modify my order. The open jaw design is convenient. The machining on the tie downs and rosette is top notch. Another note, the clamps on the motors are well designed and solid. This is replacing my now sold DJI unit. The clamps on those.......that's another story.
