Robert Andriessen
The point is that a cable of insufficient current rating when carrying a current of 10A can get excessively hot. When enclosed, the lack of convection cooling will increase that heating. A coiled internal cable, as is often used internally for audio boompoles will also increase resistance and heating.
Remember microphone cable only has to carry maybe milliamps at millivolts, so current rating of the cable is generally barely a consideration for that application. Fortunately, low resistance is desirable to minimise voltage drop here, so audio cable will be thicker than necessary for the tiny audio currents.
Edit: A casual glance at a few mic cable specifications would indicate that they are not rated anywhere near 8A, let alone 10A, and that's in open air. Will do a bit more research to double check, but looks inadvisable to use mic cable for this purpose!
thanks for checking, that's good to know how thin the cable running through the boom actually is.
