Patrick Spohrer
- Dec 25, 2007
- socal
- www.monkey-with-a-gun.com
Any plans for compatibility with Blackmagics new micro panel?
-patrick
-patrick
-patrick
Hello
i will look if I can remove repeat on that key or delay it so this does not happen...
I will report here when done.
Hello
Were you able to stop the m key from repeating?
I'm still in hope to find a good configuration that allowed me to use Foolcontrol with wifi, for two reasons:
1 - I do not use PC (only Mac) And as far as I understood, I need to use a PC to configure the hardware converter every time I need to use it ?
2 - My main purpose is to use it with a RED inside a housing, so a simple antenna with wifi in the housing is a simpler solution instead of a DIY converter using the control port.
That said, I've found that the wifi signal of RED is a little bit moody, even in infrastructure mode, no matter the firmware version. Take a look at this thread where I've posted my assumptions: http://www.reduser.net/forum/showthread.php?159772-Wifi-unreliable&p=1745163#post1745163
I would really like to make wifi a trusty option. Any thoughts?
Or a jetpack SDI module with GIG Ethernet... that's 100% reliable![]()
Hi Mikael, I have a question. Where/how do I access the single frame trigger in the Foolcontrol menu? I can't seem to find any reference to it in the forum. Thanks.
Subnet 0.0.0.0 - should this be 255 255 255 0?
Thanks for the reply. Connected to camera through Ethernet. DCHP mode displays a non 172.16.x.x number which the teradek videos says it needs to work. Everything looks connected but can't get foolcontrol to see the colr by searching for camera OR by manual IP. Not sure which manual IP to enter anyway... The colr or the camera?Yes... 255.255.255.0 for subnet
are you using ethernet between COLR and camera ?
if so you should use DHCP mode on camera setup...
direct connection setup video :
https://support.teradek.com/hc/en-us/articles/216947908-COLR-FoolControl-Direct-Connection-
using another on set router setup video :
https://support.teradek.com/hc/en-us/articles/217446317-COLR-FoolControl-On-Set-WiFi-
should work like this if all goes well
https://www.youtube.com/watch?v=EdZF77Ur4EA
