Adrian Weinbrecht
Is anyone else having issues with 6.2.44 and Nikon lenses ?
Hi Adrian and Andre,
What issues are you having? I loaded 6.2.44 up last night with a Nikon 14-24mm f/2.8G and it seemed fine, it pulled the focus and iris through their ranges while it was booting up and the iris was able to be controlled after the upgrade. The camera updated the side handle and Nikon mount as part of the update process, were your mounts attached to the camera during the upgrade?
This is on a Dragonised Scarlet-X.
-Andrew
Suggestion : Raise a ticket and report progress back in this thread.
AJ
I have issues on my Weapon now also...BUT I find that if I reseat the sense a few times and/or boot up a couple of times it at least lets me use the iris. I have the the 28-70mm 2.8 which is not even on the list and it works. Also just used my 70-200 and it works.
Obviously there is an issue and it needs to get a new firmware update ASAP and I would hope RED is working diligently and rapidly towards that end.
v6.2.51 is up on RED.com, folks. This thread's topic is addressed within.
I will load the new version Phil and see how my lenses work
Please let me/us nowI reported the issues I had with 6.2.51 to the RED support today.
Hey Adrian,
Nope. The only answer I got from support was that they are looking into it.
I am using the same "work around" on the AFS lenses. Also the lens doesn't sound very nice(the iris is oscillating from full open to almost fully closed), so I never just "change" a Nikon lens with power on anymore. btw my nikon mount was recently checked out by red with the weapon. (edit ... problem is with 6.2.51)I have issues on my Weapon now also...BUT I find that if I reseat the sense a few times and/or boot up a couple of times it at least lets me use the iris. I have the the 28-70mm 2.8 which is not even on the list and it works. Also just used my 70-200 and it works.
