Cail Young
- Jan 2, 2007
- Age
- 40
- Melbourne, Australia
- www.inspirationstudios.com.au
Pretty much... But I do have a dumb-dumb queston... Is there any way to color correct in 'Color' and have all the processes re-applied to the original 4K material via proxy or something (sort of like rendering it out in the background?) I think I read somewhere that from start to finish [in final cut studio 2] one could end up with 4K output (even with Color).
If I understand Ted correctly in the hdforindies interview;
You import REDCODE RAW 4K into FCP6. Do your edit. FCP6 will dynamically pull low-res proxies of your shots from the original files, no re-render required.
Once your edit's done, you bounce to Color. Color reads in the FCP timeline and has access to all of the original 4K data, which you can then render at any resolution you like.
