Anders Holck
- Dec 28, 2006
David.
How I understand it:
In the end the the Red camera will record in 4k and 2k Redcode RAW, 1080p and 720p Redcode RGB. Only in camera Redcode RAW will be enabled in the first cameras.
In the end Mac support will come in three steps:
1. Redcine
2. Normal Quicktime codec, for RAW and RGB support in all QT applications.
3. Enhanced FCP support.
Redcine and hopefully the normal quicktime codec will ship with the first cameras.
Later a FCP update will enable the enhanced support inside FCP.
You will get a P2 like import dialog with the ability to transcode into another codec and framesize.
You will also get RT extreme enabled Redcode.
Redcode RAW can be debayered on the fly. The Wavelets inside a wavelet codec allows it to skip layers to quickly get a half res or quater res image. Based on the performance of the processor and the destination sequence resolution, the codec can "gear down" the resolution on the fly, to keep the framerate. So while the sequence is plying you get a lower res but smooth framerate, and when you stop playback the codec switches to a high quality debayer. This is like the DV codec and DVCPRO codec currently functions inside FCP, it will gear down on the fly, with no user intervention.
If you choose to convert to another codec or framesize before editing, you can always recconect to the original RAW files and then do a consolodate in the mediamanager to get the final timeline in RAW, or you might have to export the timline as an XML and reconnect inside Redcine.
This is just one scenario.
There is really no info on what exactly is holding back in-camera Redcode RGB. Either the codec specs are done and they are waiting for the embedded version to get finalized, or the spec is not compleately finished and both the embedded version and the Quicktime codec are getting finalized.
Of course if it's the latter The quicktime codec will not be available until a later time, and youll have to use another codec, if you want to use an intermediate format.
1. Redcine
