John Marchant
- May 4, 2010
- Normandy, England
- www.kippertie.com
EVF and HDMI use the same path - so its one or the other AFAIK
In my opinion it's not really usable when docked to the camera. Get the wooden camera evf mount so u can slide it way forward and whatever distance away from the body you want. Same with the monitor, cableless is cool but not really useful in a normal production environment
You could also look at the BM Ursa EVF. Its 1080p oled and decent optics as well, only around $1400. For use on Dragon/Weapon, DC in is on a XLR, I just chopped that off and added a 2pin lemo, then its just SDI to the brain.
A million times better than either bomb evf. The DSMC2 EVF sounds ok, but still no shutter to block off sunlight damage, no heated eyepiece, doesn't appear to have any better way to a secure eye piece chamois/cushion. I use to worry about being out in the middle of africa with only sdi monitoring and loosing the menu displays, but with a sidekick that wont be a problem.
For about 4x the cost I'm waiting to try a dcmc2 evf in person before ordering.
Received mine today and it is amazing!
I have one problem so far, I can't control the main menu (frame rate, iso, wb, etc...) into the EVF screen and only through the Sidekick.
Even when the control mode is on LCD2... Pretty sure I'm missing something but I can't figure out what...
Any advice?
