DSMC2 Beta Firmware 6.4.21 , Scarlet-W and Weapon MG Spec increases
Quick response ! Thanks
Any one checked out the wooden camera cableless
V mount plate for the battery remaining indication ?
I bet you $20 they will roll out with higher frame rate 4k Prores for helium cameras, eventually.
watch. :)
RED continues to impress, customer service and transparent communication is second to none! Great to be a part of this community!!!
• Added Avid Codecs DNxHR HQX at 4K (4096 × 2160) 12-bit up to 29.97 fps, DNxHR HQ, SQ and LB at 4K (4096 × 2160) 8-bit up to 29.97 fps
Wait... what...? That's quite the update :beer:
Wow, you guys are fucking amazing and seriously the best at everything.
Sales Team - Best in the biz
Product - Best in the biz
Customer Support - Second to none
Communication - No company on earth operates like RED. Innovation from top to bottom. Communication is key and RED's transparency and feedback with its customer base is unparalleled.
You guys rock!
Thank you Jarred and everyone at RED!
That's great! I've upgraded to the latest firmware succesfully on my S-W.
I only can choose the LEGACY pipeline, I understand that Color Space and Gamma Curve are just metadata, but they effect the way I expose.
I used to work with DRAGONcolo2 and REDlogFilm and I used to create the color presets in camera or using foolcontrol.
Now that it's possible to use the 3D lut what shoud I use as Color space and Gamma Curve?
Just give it a try and I have new issues compared to the first beta ..
1- sometimes side handle is the only way to control the camera. Touch screen (5") doesn't respond
2- Focus using edge tool can't be disabled. Screen is locked on the Edge tool. Shutting down af on the lens solve the problem. (all lenses. Sigma art : 18-35 / 24-105 / 30mm 1.4 / 50mm 1.4 and canon L : 100mm / 100-400)
3- Impossible to record anything. All the record button do not work.
4- Sometimes when the record button work .. it stop recording when focusing and the yellow icon doesn't disappear. Then it is impossible to shutdown except by using the start button
5- Impossible to format media. Even the secure format doesn't work.
And finally impossible to save a log file. "Error. Impossible to save log file"
I have reboot several times and each time I have different issue (very randomly) from the list above.
Except this little points, everything works fine, especially the ipp2 pipeline !!
It seems you break other things :)) Almost, almost !! I'm kidding, I wouldn't be able to do the half of the things you do, so this is just a quick feedback to help as I can't save a log file !!
