Danai Chutinaton
- Feb 7, 2011
- Bangkok, Thailand
- www.bluepano.com
OK, thanks!
I don't have a set of Mitomos here unfortunately. They are the "newest" to the street and I'd love to test them out.
I thought i would start this thread as i started one about the epic that went very quiet.
Since i am waiting for my Epic M to be upgraded to Dragon i was wondering does the dragon require the use of IR nd's with a hot mirror in front like the Epic.
I have been on a shoot for the last week where i was still getting IR pollution on my Epic M with 1.5 + .9IRND with a hot mirror in front so i could sit at T1.3 on my super speeds.
Has anyone tried this on the dragon as i am in the market for a new set or IRND's since i have 2 sets of normal ND's and a hot mirror and i don't want to waste my money if the dragon doesn't need them.
I have a Epic-X MX and I'm trying to decide whether to invest in a set of IRNDs or NDs with separate Tru-Cut IR 750 filter. Specifically, I am looking at the "Schneider 4x5.65" Essential Filter Kit for RED" vs a set of Pancro IRNDs.
I want a setup that is future-proof (Dragon) as well as functional with cameras from other manufacturers.
What would you guys suggest?
I actually think using IRNDs can be the cause of some people finding their camera noisy. I have a feeling that the IR Cut in the new OLPF probably gives the image a green cast that is dialled out internally by adding Magenta (which pushes the Red and Blue channels). If you then use heavy IRND, you add even more Green that needs to be dialled out through the white balance, meaning the Red and Blue channels are being pushed even more! Seeing as outdoors you are getting plenty of blue light already, you end up with an underexposed red channel that is being pushed quite a bit which results in some Red Noise.
Just my theory at the moment with the few tests I've seen with the new OLPF.
Why are you guys recommending Formatt Firecrest? According to this blogpost at Ablecine they are IRND's. But with Dragon you don't need the IR cut. Just wondering. I ask because I'm trying to figure out what to buy to replace my old IRND set.
Thanks.
