- Thread starter
- #321
Ketch Rossi
- Jan 10, 2007
- Sardinia, Italy
- www.afroditefilms.com
Hi Ketch!
I've used a lot of gimbals but the RONIN seems like a much better solution than all the others...
I currently own an FS700 and the only thing I'm concerned about is when/if they will be making the XL arms?
Great thread and I'm looking forward to the review!
Andreas as Rome is Correct, the XL Kit, is still in development for final touches and hopefully soon to be ready and ship out to awaiting customers, I had suggested that the Kit were not only to be longer Arms but also third longer center arm as to allow better quicker balancing of the center of gravity of the actual Ronin thru the center arm & Axis, so DJI has been great and listing to the early Beta testers and I am hopeful that such design will be implemented and finished soon so that I can receive that Kit and put it to final test and get it out there.
But the Red Epic is perfectly balanced in a variety of art ups on current Ronin as easy as it can be, and way easier then on the Movi or on few other currently available Gimbals, so not to worry at all.
Andreas,
I asked Ketch the same question. I think he said the arms are still in development, but aren't ready to ship now...but I don't want to speak for him, so I'll let him respond. But, he did say that the current arms are fine for the Red Epic...hopefully, they should work for your configuration.
Ketch,
Quick follow-up question.
I basically want to know if you can hook a belt clip (from Red, the DSMC model) to the Ronin, and still have the functionality? Or will the cord somehow restrict motion? I know some motion (like the flip upside down) won't work, but for all the other basic motions, will the wire connected from something like a belt clip to the camera on a Ronin be good/bad/or just ugly in terms of functionality?
As always, a sincere thank you for your time and contribution! I doubt I (or a lot of other Redusers/other forum watchers) would even be considering a Ronin rig if it hadn't been for your writeup...and the pending review (although you've basically already gave it pretty positive reviews).
Thanks Ketch!
Rome, a belt clip could be used, but is to be considered that anything that comes form a Cable connected device not directly mounted on the Ronin that can sin freely with it, will at some point impede it's movement, and in this it's stabilization, however it can be used as I have tested it with great success, but you can't go reverse mode form standard mode with it, but you can go to briefcase mode and back no problem, but the moments need to be slow, and the cable been that it is not a thin and as flexible as it should be does pul a little on the Ronin, but those motors are really strong and do a great job at not allowing the cable to effect the stabilization.
Try it out yourself and see what I mean, you'll see that there is a lot you can do, but some moves just can't be done.
