DAVINCI RESOLVE and ***HACKINTOSH***
Hi Lugi, have you successfully installed Resolve 8.0 in LION GM..?
Ciao ARjun , not yettt ,, waiting update ;)
I just got my evga Classified SR-2, only waiting for x2 Xeon now... I'll be testing this week. I've been so busy this year. I've had little time for testing. hopefully I can relax and do some troubleshooting with Lion on SR-2/
I hope that we can for you, especially chipset network cards Marvel 88E8057, it would be a pity to lose the PCIe slots for network cards.
greetings ALex ;)
ciao
Luigi
greetings ALex ;)
ciao
Luigi
Just got my x2 Xeon's today, I hope to try it out tomorrow. Not sure about Ethernet too. I'll have to edit the Kext to find out.
EHEHE SURPRISE ;)
LION GM and DAVINCI RESOLVE 8...:w00t:
PATCH to database DAVINCI WORK ......
and CUDA WORK correct... 4.0.19
Luigi
Wow :) Thats really gud news Luigi ..
You have done it again...
can you please share us database Patch or steps to make it work.
Create postgres is user account with password: postgres and in terminal use this:
cd /Library/PostgreSQL/8.4
mkdir data
chmod 700 data
chown postgres data
su postgres
./bin/initdb /Library/PostgreSQL/8.4/data
(Watch it go and then you can start your server via)
./bin/postgres -D /Library/PostgreSQL/8.4/data
or
./bin/pg_ctl start -D /Library/PostgreSQL/8.4/data/ (for daemon mode, pg_ctl --help has a full list of commands)
Now in a new tab try /Library/PostgreSQL/8.4/bin/psql -U postgres and all should connect.
If you are using just psql without the full path it will load the default Lion psql command, is possible Davinci not run with this error,
dyld: Library not loaded: /usr/lib/libpq.5.dylib
Referenced from: /usr/bin/psql
Reason: no suitable image found. Did find:
/usr/lib/libpq.5.dylib: no matching architecture in universal wrapper
Trace/BPT trap: 5
or rename libpq.5.3.dylib with libpq.5.dylib
THANKS
Luigi
but remember is better wait Blackmagic for this .. but if you want try davinci with Lion ...
mkdir data
chmod 700 data
chown postgres data
su postgres
or
Trace/BPT trap: 5
THANKS
Luigi
Hi Luigi,
Great job on figuring out the DB to get it to run on Lion :-)
We strongly advise users to not use Lion right now, as there are multiple known stability and performance issues on Lion right now. If it's just for a test, then it's ok, but you will run into many issues.
Regards,
Rohit
Hi Luigi,
Regards,
Rohit
Thanks Rohit ;)
Right, only use for testing, not use for GRADING....
Actually being there are still problems with the restart of the database when you restart your Mac.
thanks
Luigi
Speaking of database issues. I've had to do a repair-permissions on my drive a couple times to fix other issues not related to Davinci. However, both times this has screwed the permissions for PostgreSQL, thus leaving Resolve unable to connect to a database (or create a new one) and launch. I had to remove the PostgreSQL folder and reinstall Resolve to fix it. Kinda weird.
Kinda weird.
Yes Jeff you are right, in Lion the problem of PostgreSQL is the DATA folder , no create for default...
Jeff you've tried with your beautiful Epic-M HDRx with Davinci?
I'm curious;)
thanks
Luigi
Hi Luigi new kid on the block here i been watching this thread for a while and wish i could run the multiple 470's for rersolve but for now i only have access to the gtx 285 and the gt 120 is it possible to get both to work together in a hack? i'm using a GIGABYTE Z68X-UD7-B3 intel Motherboard any info would be appreciated thanks in advance for your time.
ciao DEAN,
FOr gygabyte Board talk with JOSe Lomena in this forum , me i make support only for p6t7 ;)
ciao
thnaks
Luigi
thanks for replying luigi :) i will ask JOSe Lomena for his help thanks again.
luigi if you dont mind me asking can dsdt editing help using two gpu's? my 2 cards show up in about info but resolve would not use 1 for gui and other for cuda
dear Dean,
dsdt is for acpi....
you see my for page section tips and triks?
you go at post 47, open debug mode anda paste this:
LsManager.3.NumGPUs = 2
LsManager.3.GPUMapping = 0 1
LsManager.3.GPUMappingEnable = 1
well save, logout and login..
try .
i repat talk with JOSE , but this board you go to bios for change priority pcie grapchis boot.
thanks
luigi
well my friendssss...
i am at work for "machete" beta 1, this installer is ready with video tutorial for the end of this week.
This installer is only for P6t7 WS asus supercomputer and new LION Osx with 3 or 4 gtx 470/480.
For user with only 1 gnu in this moment not have a time for patch dsdt.
thnaks Luigi
Hello my friendsssssss,
A promise is a promise ... slightly in advance;) :001_smile:
Machete beta 2 is ready, of course, where having the original Lion.
Well what is the Relais Machete GENERATION CUDA is an installer that will help you to install,
the mainboard ASUS P6T7 supercomputer, the Apple operating system Lion 10.7.
In collaboration with the Team InsanelyMac, Ermac, we ended up in Beta2 version of this installer but it works.
What's' new and what we want to introduce:
1. Support 6 CPU core i7 1366 / i980, i980x, i990x + 6 core Xeon
2. Sleep native, you can now put on standby and on again. ;)
3. Provisional support for tests 3 and 4 GTX 470/480 , not support for only 1 GPu in this moment .
4. Digital audio works.
5. Support REDROCKET
5. Support for Blackmagic 3D
What we would like to introduce in the next relay:
1. Support the GTX 570/580 and possibly 590.
2. speed up the boot in 6 seconds with a script to fix the start of the kext cache.
Another possibility would be to use 1 ATI 5770 and 2 GPU 580, if you are open to discuss ideas for now enjoy.
install:
1. Follow Video tutorial for 1 part.
2. disconnect all hard drive and dvd and connect only Lion Hd in sata1.
3. install lion and ejoy in lion.
4. re run my installer and see the pics part2, select only driver and install and reboot ;)
5. connect all HD and DVD at your sata.
6. power on and Enjoy in Lion 10.7
thnaks
Luigi
download this:
https://rapidshare.com/files/1932121257/Machete_beta2.zip
Hello Luigi
I´m following your steps, I have a system with the asus, 3 gtx 470 and blackmagic. I followed the installations step by step, but I have a problem.
The computer is booting at a low resolution and can not be adjusted, its like the OS does not recognize the cards. The card and in slot 3, 5 and 7 counted from the CPU.
The only difference is the CPU, i´m using a Core i7 970 (6 cores).
Any help will be great.
Gaston Musarra
Hello Luigi
Gaston Musarra
contact me gmail :
luigi.valtulini (at) gmail (dot) com
i wait ;)
