Björn Benckert
Assuming you are talking about the Nyrius, I think that would connect with a laptop through HDMI, then perhaps you could send to a tablet or phone via wireless or even bluetooth from the laptop?
I've used the Nyrius to connect wirelessly to a monitor before, and their overview says you can send content FROM a laptop to a TV, but I've not heard of or tried to send from camera to laptop though.
No time to test at present.
I tested a few different of those h.264 wifi options the terradeck and some consumer options... none of them will really work. They could possibly transmit picture in between their fallouts which will for sure happen quite often. My experience was they they kind of worked well when I tested them but on set when things matters they lost signal so often so in comparison to the hassel of having a bnc cable to the camera... well the BNC wins. Also they lag quite a bit. Which is super frustrating when used as a director or even client monitor. So in the end I had to bite the bullet and buy a terradeck bolt, te bolt works well enough. Not much lag and lost signal does not mean I have to go and click on some computer or antenna to make it work again as the signal comes back atomaticly as soon as the antenna is in reach. and the picture quality is much better. An ipad can not take streaming video without adding a huge lag. So I do not see them as even close to being an option. but I like to see you try, possibly things changed now.
